GAMING
Top 10 PC Gaming Headsets
Author: Chet C.
Guy with Headset
If you’re considering buying a new gaming headset, there are several important factors to consider: the sound needs to be clear and balanced, the microphone should be good quality, and the headset needs to be comfortable to wear for long periods of time. Bearing these factors in mind, here are our top 10 picks. We’ve split them into three categories so you can choose according to your budget.
High-End Gaming
Qpad QH-1339
For superior sound and microphone quality, you can’t go wrong with the Qpad QH-1339 Pro Gaming headset. Reproducing sounds to immaculate quality, even when you’re in a loud environment, you’ll feel totally immersed in your gameplay. So much so that in-game explosions will sound so realistic, you’ll feel as though you’re there. The QH-1339 headset is compatible with all standard audio devices and comes with a five-year warranty.
Creative Sound Blaster Recon3D Omega
Offering wireless technology and cross-platform compatibility, the Creative Sound Blaster Recon3D Omega headset is ideal for immersive gameplay on Xbox, Playstation, Mac or PC. The THX TruStudio Pro sound technology produces hundreds of virtual speakers above, below and around you, generating super-realistic sound and surround effects. For the clearest communication via the microphone, this headset uses four CrystalVoice™ voice enhancement and clarity technologies, including noise reduction, smart volume, FX and acoustic echo cancellation. For a comfortable and precise fit, the headband has a steel core which offers durability while playing for long time periods
Good All-Rounders
If you have a modest budget and you want the best of all scenarios, you might be interested in:
Kingston HyperX Cloud
Memory foam ear cushions ensure day-long comfort, while the cross-platform compatibility of the Kingston HyperX Cloud headset means you can use it with PS4 consoles, mobiles, PCs, tablets and notebooks. The closed cup design allows for complete noise cancellation so you can concentrate on the game in hand. For your peace of mind, this headset comes with a two-year guarantee and free technical support from the manufacturer.
Kingston HyperX Cloud II
The upgraded version of the HyperX Cloud, this headset provides the user with 100 per cent memory foam padding on the headband and leatherette cushions for superior comfort. You’ll also benefit from advanced surround sound, giving you the ultimate audio experience. Compatible with the latest consoles, including PS4 and Xbox One, as well as mobile, Mac and PC, the HyperX Cloud II is a good all-rounder.
Steelseries Siberia Elite
With ‘elite’ in its name, you know this is going to be a good headset – and the Steelseries Siberia Elite does not disappoint. Featuring Dolby ProLogic IIx technology, you’ll enjoy a rich and immersive experience with natural and realistic surround sound. With super-thick, memory foam-packed cushions that completely envelop your ears, you’ll not only find this headset one of the most comfortable; you’ll also experience superior acoustics and passive noise reduction.
Steelseries 9H
With no need to install software, the Steelseries 9H headset can simply be plugged in and it’s ready for gameplay. You also have the option to adjust and personalise all of your equaliser and audio settings, with the ability to save up to eight settings for each game profile – ideal if you’re sharing the headset. The extra-padded design enables passive noise reduction and provides extended comfort for day-long gaming, while the microphone is retractable and can be hidden in the left ear cup when not in use.
Best Budget Headsets
Having a small budget doesn’t mean you can’t enjoy your gaming experience. Check out our favourite budget headsets:
Logitech G230
For high-quality stereo sound, you can’t go wrong with the Logitech G230 headset. Experience full in-game immersion and comfort all day long thanks to the sports performance cloth ear cups. Lightweight and slim, you’ll forget you’re wearing a headset. The noise cancelling microphone has been designed to only pick up your voice, and can be folded away when not in use.
Gamdias Hebe
Make your comfort a priority with the Gamdias Hebe headset. Its lightweight construction and leatherette cushioned ear cups provide lasting durability and comfort for hours of gaming. With a rich audio experience on account of the professional-gaming level magnet driver units, you’ll feel completely immersed in the game.
Gamdias Hephaestus
The Gamdias Hephaestus is all about cutting-edge technology – who said the best was the most expensive? Combining 4D experience with in-built cooling system, this headset was designed to deliver on all levels. Offering superior comfort and a more realistic gaming experience, misjudging your enemies’ location is a thing of the past. The noise-cancelling microphone assists you and your team mates with communication, blocking out the background noise – what more could you ask for?
Corsair Raptor HS40
If extended gaming sessions are your preference, look no further than the Corsair Raptor HS40 headset. With padded ear cups and headband, this headset offers day-long comfort, while the 7.1 surround sound and noise cancelling microphone keeps your ear in the game and prevents any background noise distraction.
So there you have it – you’ll be well-equipped with one of our recommended headsets. Browse the full range of gaming headsets at BT Shop today.
Need it in a hurry?
Express delivery available on selected items
Over 10,000 products
The latest technology from the biggest brands
UK customer service
Our people are on hand Mon to Fri 9am - 5pm
Over 25 years of experience
Trusted by customers for over two decades
